unconfigure ldap domains
Description
This command deletes all LDAP domains, and thereby all LDAP servers and other LDAP configurations done for those domains.
Syntax Description
Default
N/A.
Usage Guidelines
Use this command to delete all LDAP related configuration from the switch.
The following command deletes all LDAP configurations, LDAP servers and LDAP domains.
Switch.25 # unconfigure ldap domains
This command was first available in ExtremeXOS 15.2.
Platform Availability
